fiero idle
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=309
Printed Date: 08 May 2025 at 12:04pm
Topic: fiero idle
Posted By: Guests
Subject: fiero idle
Date Posted: 02 August 2007 at 6:55pm
hey i have a quesiton ...wen i start up my fiero at times it revs so low liek tis about to stall but it jus rises bak up what do u think is wrong?
Date Posted: 02 August 2007 at 7:36pm
IAC could be sticky, vac leak - could be many things.
Is it only when cold?  Only hot?  All the time?
Posted By: Guests
Date Posted: 03 August 2007 at 2:13am
ummm both ? only sumtimes though
Date Posted: 03 August 2007 at 7:14am
I'd start with your IAC then.
Posted By: 88FieroGT
Date Posted: 03 August 2007 at 5:26pm
Mine does that too. It starts like normal then dropps down to 500 rpm then back to normal then idles normally. It only does this occasionally and only at the first start up of the day.
Posted By: Guests
Date Posted: 10 May 2008 at 1:02am
so did u fix that problem 88fier0gt?
Date Posted: 10 May 2008 at 11:50am
No but it is not doing it now. It only does it between august to october.
Because it is not doing it now, I wouldnt know if I had fixed it or not. Sorry.
Have you fixed yours?
Posted By: Loops87GT
Date Posted: 10 May 2008 at 5:59pm
this sounds like it happens to alot of fiero owners. seems like theres a post about it every other day on PFF
