Idle rpm’s (potential vacuum leak)
URL: http://www.westcoastfieros.com/forum/forum_posts.asp?TID=2785
Printed Date: 20 June 2025 at 9:59pm
Topic: Idle rpm’s (potential vacuum leak)
Posted By: brad12329
Subject: Idle rpm’s (potential vacuum leak)
Date Posted: 18 December 2011 at 4:02pm
Hi, what rpm are you guys idling at when engine cold and warm?
I took off my intake plenum to paint and now that i put it back on i'm idling at around 900-1100 seems higher than i remember, do you think i have a vacuum leak?
Date Posted: 19 December 2011 at 2:56am
900 seems about right. 1100 is a bit too high. It is cold these days
so that might have something to do with it.
Once it's warmed up, does the idle go down?
Date Posted: 19 December 2011 at 9:28pm
Okay so i got the service engine light, it is code 35. Could be a vacuum leak or bad iac valve. Basically my car idles at 1500 until warm then drops to 1100, once warm and restarted idles at 1500 for about one minute tops then back down to 1100.
I read online to test for leaks with a propane tank, i put it up to all the vacuum lines i could find and no stumble or change in idle. i thought it might be throttle body gasket or intake gaskets cause the idle problem started after i re installed my plenum after painting it, but nothing. I put on new gaskets so they should be fine.
The internet said maybe egr but my egr is dissabled on my reprogrammed ecm.
Could any of this be caused by a dead battery cause i hadn't started my car in a while and had to jump it. I tried resetting my iac from the method i found on pennocks. it helps in the sense that it idles at 1100 instead of starting at 1500 then slowing to 1100 after one minute but its not the 900 my car was idling at before this.
I also read that i need to drive above 35mph for a minute to re adjust the idle but my car currently doesnt have insurance, anybody know if there is any truth to this and if it would apply to my situation.
I was thinking of getting a new iac and see if that fixes it, if not then it would rule it out then i know i have a vacuum leak.
Any help is greatly appreciated, thanks guys
Date Posted: 20 December 2011 at 1:29am
You don't say what engine you have, but if it's the 2.8, I'd say your EGR tube is cracked.
Date Posted: 20 December 2011 at 6:52am
It is a 1986 2.8l v6, i assumed it wouldn't be the egr cause it was disabled at the ecm. I pull of the vacuum line to the egr and no change in idle, unless the braided tube still is functioning and not the vacuum line.
Date Posted: 20 December 2011 at 11:41am
That makes no difference. The flexible metal tube is still connected to the underside of the intake manifold. If the tube is cracked (or not attached properly at either end), air will be sucked into the intake system.
If your ECM indeed has the EGR deleted/disabled, eliminate the potential problem of a cracked metal EGR tube by installing a small plate over the opening on the underside of the intake manifold.
Date Posted: 20 December 2011 at 3:14pm
What Patrick said and actually remove the EGR and plug or weld up
that hole also. One of the great benefits to doing the EGR delete is
not having that huge chunk of very hot metal near your ignition
system. That ignition system does not like being hot.
Date Posted: 20 December 2011 at 8:00pm
Okay mission acomplished, those little bolts were hard to get to but i slid a piece of a pop can in there and it worked!!!
Thanks guys, she runs beautiful again :)
And sounds very nice since removing my cat and putting a straight pipe in.
Date Posted: 20 December 2011 at 9:16pm
...and it worked!!!
Don't sound so surprised!
