Fuel |
DeathLight443 ![]() Newbie ![]() ![]() Joined: 04 June 2012 Location: Canada Status: Offline Points: 11 |
![]() ![]() ![]() ![]() Posted: 01 August 2012 at 12:40am |
I got a 1985 Pontiac Fiero V6. Im just asking, how much liter do I put in it. On the internet, My fiero can take 40L. So i tried it. Empty my gas tank and try it. BUT It only took 25-30L. If I take more fuel then it will overflow and the gas will come out. Any help here???
bcampbell ![]() Senior Member ![]() ![]() Joined: 14 November 2011 Location: Canada Status: Offline Points: 160 |
Chances are there's still fuel in the tank when the gauge
is reading zero. That's the only thing I can think of. It's the same in my car. |
'89 Firebird 3500T, T56 |
At least your gauge is reading on the wrong side that way!
Most Fieros run out of gas when the gauge reads 1/4 tank. The 85's had a slightly smaller tank than the 86/7/8's which were (45L?). |
YUUUP. ![]() |
When I had my gas tank off I cleaned the resistor on the sending unit
and I can drive till my gauge goes to zero. (although I haven't tried going past 1/16th). Before cleaning it would read full constantly and resistance was 3 times that required to max the gauge. |
Totally common problem...
It should read between 0 and 90 ohms, with a linear sweep between. Sort of need a graphing meter to really see it, and to see if you have high or low spots. But in a pinch a normal meter will do. They get varnished over the years. Almost all GM fuel level sensors do it! |
84-86 10.3 Gallons or about 40 liters 87-88 11.9 Gallons or about 50 liters Basic rule Empty on an 85 is 30 liters empty on an 88 is 40 liters. They usually have about a gallon or 2 in the tank after a correct gauge reads empty. Side note for those that don't know, the Fuel Pump is cooled by fuel running through it, if you run a Fiero pump empty you reduce its life considerably. So don't make a habit out of running out of gas or you will get in the habit of replacing fuel pumps. |
