FS Linksys Power over Ethernet System $40 |
![]() ![]() ![]() ![]() Posted: 23 March 2008 at 5:28pm |
I have it posted on Craigslist, but figured some of the club guys might be interested. You can run a simple Ethernet cable say out into a garage or building that does not have power, and use this setup to power your router. Here is the Craigslist ad. Link to Forsale Page LINKSYS Model: WAPPOE MODEL- WAPPOE VENDOR- LINKSYS FEATURES- Power Over Ethernet Adapter Kit Simplify your network installations with power and data on one cable! The Linksys Power Over Ethernet Adapter Kit lets you put your access points almost anywhere, by removing the requirement of nearby power outlets. By using the existing Category 5 Ethernet cabling to deliver power to any standard 5 volt access point or other network device, you save the time, hassle, and expense of running AC power to the access point's installation location. The best position for a wireless access point is usually on the ceiling, in the center of the area to be covered. Second best would be high on a nearby wall. Unfortunately, there's usually no easily accessible AC power plugs available in these locations. With the Power Over Ethernet Adapter Kit, installing the access point in these preferred spots becomes far less trouble. The Power Over Ethernet Adapter Kit is a two piece set. The "Injector" sends both power and data over one Category 5 cable to your access point, wireless router or bridge. Then the tiny "Splitter", placed at the remote location, separates the network data and DC power back into two cables, and delivers them to the access point. The Injector can also be used by itself with POE- enabled network devices that accept 48 volts directly on a POE port. When it's time to expand your wireless network, let the Linksys Power Over Ethernet Adapter Kit simplify your installation. * This product is compatible with the following Linksys products: BEFW11S4 Ethe rFast Wireless AP + Cable/DSLRouter with 4-Port Switch WAP11 & nbsp; Wireless Network Access Point WAP54G Wireless-G Access Point WET11 & nbsp; Wireless-G Ethernet Bridge WET54G Wireless Ethernet Bridge WAP55AG   ;Dual-Band Wireless A+G Access Point WAP51AB   ;Dual-Band Wireless A+B Access Point BEFSR41   ;EtherFast Cable/DSL Router with 10/100 4-Port Switch BEFSR11   ;EtherFast Cable/DSL Router BEFSR81   ;EtherFast Cable/DSL Router with 8-Port 10/100 Switch HPRO200   ;HomeLink Phoneline 10M Cable/DSL Router BEFVP41   ;EtherFast Cable/DSL VPN Router with 4-Port 10/100 Switch www.linksys.com |
